It is currently Fri Jul 24, 2026 12:25 am
PostPosted: Mon Mar 23, 2015 5:49 pm
So I have a single coil guitar (epiphone casino - p90's) and I understand that there is hum with single coils but I have played on other tube amps and the hum has been minimal, it is strange because the hum on the tweed over powers the sound of the guitar. Do I need to shield the amp and/or the guitar???
Cheers and Thanks
PostPosted: Mon Mar 23, 2015 5:53 pm
Sounds like you have a grounding issue with your amp. Post some pics of it.
Could also be a bad cable, dirty power, bad tube, etc.
PostPosted: Mon Mar 23, 2015 6:53 pm
When the guitar is unplugged from the. amp, does it hum loudly? That will probably tell you if its guitar or amp related.
PostPosted: Mon Mar 23, 2015 9:30 pm
When the guitar is unplugged the amp does not hum, however I can play with other tube amps with minimal hum with the epiphone casino p90's. The tweed amp did not hum when I played it with the an epiphone dot.
I can minimize the hum to almost nothing if I play the guitar at a certain angle in relation to the amp but it has to be a a very specific angle and any little movement outside of that specific position the hum comes back and overpowers the sound of the guitar.
Cheers and Thanks
PostPosted: Mon Mar 23, 2015 11:05 pm
Sounds like shielding in the amp maybe but certainly its not entirely amp related.
PostPosted: Mon Apr 06, 2015 8:21 pm
where should I shield and with what material just copper or are there other options
Cheers and Thanks
PostPosted: Mon Apr 06, 2015 10:37 pm
Get some Aluminum Tape from Home Depot, heating ventilation dept. shield the panel covering the rear with that.
