It is currently Wed Dec 03, 2025 12:12 pm
PostPosted: Tue Oct 27, 2015 4:40 pm
Does anyone have a close up visual of how to prepare the coaxial cable for connections. Thanks!
PostPosted: Tue Oct 27, 2015 4:41 pm
This is for the volume control
PostPosted: Tue Oct 27, 2015 6:23 pm
Should be in the builders guide
PostPosted: Wed Oct 28, 2015 2:24 am
Here's the only picture I have of the coax cable at the volume control. I basically followed the instructions in the manual. The shield is covered with red heat shrink tubing and there's more heat shrink tubing around the cable where the inner conductor and the shield come out.
The shield isn't connected at the other end so it just gets cut off flush with the outer insulation and some heat shrink tubing goes around the end of the cable to ensure that the shield can't touch any part of the chassis. If it does it could cause a ground loop resulting in hum.
PostPosted: Wed Oct 28, 2015 6:15 am
Here ya go Chris, a great tutorial by Stephen from 2008 he probably forgot he did this one.
viewtopic.php?f=2&t=1144
PostPosted: Wed Oct 28, 2015 1:22 pm
thanks!
