It is currently Sat Jul 05, 2025 5:31 am
 Post subject: Eyelet wiring technique
PostPosted: Sat Jan 02, 2016 1:57 pm
Hi folks,
First build. Still trying to think ahead as much as possible. I have the eyelet board wiring laid out with the jumpers on the bottom and most of the flying leads connecting from the bottom as well. Haven't soldered yet. I've checked the forums for opinions on whether to run the jumpers above or below the board. Cosmetics vs future serviceability I presume. I'm also thinking that running all wires into an eyelet from the same direction would make for better crimping/wire twisting. I'd welcome input on this. What I'm thinking of doing is running jumpers underneath but leaving lots of extra lead (not too much) on top of the board rather than trimming the excess. Thanks in advance for any thoughts people have.
PostPosted: Sat Jan 02, 2016 2:53 pm
HI George
I would run the jumpers on the bottom of the board. It would be kind of messy to run them on the top. Running the jumpers on the top works if they all line up along the edge of the board. But these would end up running underneath some of the resistors and capacitors if they are on the top. The flying leads can go on the top if you want.
Don't twist or crimp any wires in the eyelets. You want them easily removable if you have to work on the amp in the future. Just run the wires through the eyelets and bend them over a bit on the other side to help hold them in place while you solder. Don't solder an eyelet until all the wires, resistors and capacitors going there are in place. You can trim the excess lead length fairly flush to the board, too.
Pictures of the top and bottom of the board in my Tweed are attached. Note that one eyelet is not yet soldered because that's where the output transformer's center tap wire will attach. You can see how I've bent the leads there over a bit to hold the resistor and capacitor in place and I've also trimmed them fairly flush. That's how the wires are at all the eyelets.
Eyelet board wiring is easier than it seems. You will get the hang of it pretty fast.
