It is currently Sun Sep 13, 2026 5:08 pm
 Post subject: Speaker doping
PostPosted: Fri Jan 22, 2016 10:08 am
Does anyone know what to use for the doping of speakers?
 Post subject: Re: Speaker doping
PostPosted: Fri Apr 08, 2016 2:50 pm
I had a buddy who used contact cement. I have never done this nor can I confirm that it works.
PostPosted: Fri Apr 08, 2016 3:25 pm
No idea nor do I know if you can buy the dope? What are you trying to accomplish?
It has to be very light weight otherwise you will change the speaker very dramatically. I definitely would not use contact cement!!
PostPosted: Thu May 18, 2017 5:13 am
Hello there! actually i really want to know about the use of the doping of speakers?
___________________________________________________________
Online Dissertation Proposal
PostPosted: Thu May 18, 2017 7:38 am
Speaker Doping
Doping the speaker is a commonly misunderstood concept. Lot’s of people ask about it and it is really very simple. Speaker doping is adding the shiny goop you see around a lot of speaker surrounds. This adds rigidity to the speaker itself, extending the life of the surround and controlling the cone at higher volume levels. Most often, doping is offered during the reconing process and can add life to your speakers. However, the doping process also dampens the cone vibrations, resulting in a reduction in texture and character of the speaker. In guitar applications, doping is useful when using higher wattage amps and helps reduce the possibility of unwanted surround resonance and stray frequencies that seem to step all over your singing solos. It seems a majority of the guitar purists out there prefer to have undoped speakers to attain the most natural tone but you should let your own ears decide which is best.
PostPosted: Mon Dec 21, 2020 4:41 am
Some recommend white glue or wood glue, and I've seen speakers doped like this, but that material seems to me to dry too hard. No idea if it works but you can try it at least something.
https://essaysexperts.com/dissertation-literature-review-writing-help.html
PostPosted: Fri Sep 09, 2022 6:13 am
Thanks a lot for help!
PostPosted: Sat Sep 17, 2022 6:43 am
essay writing service
Interestingly, I thought one guy sounded better with the undoped speakers, while the other guy sounded better with the doped speakers.
PostPosted: Mon Oct 17, 2022 6:12 am
Thanks for taking the time to discuss this, I feel strongly about it and love learning more about this topic stumble guys
PostPosted: Thu Sep 14, 2023 11:06 pm
Doping stiffens the cone, most often used around the perimeter. As speakers wear in, the perimeter gets softer and softer. Taylor Swift 2048
PostPosted: Wed Oct 30, 2024 6:31 am
tattonguitars wrote:
Does anyone know what to use for the doping of speakers? strands hint
You can rubber compounds: Often used for their flexibility and durability
