Hello,
I am a first time amp builder working on my Tweed kit.
I have wired up the heaters, power transformer, fuse holder, stand-by switch and the pilot light socket. The instructions say it is now a good time to check that the power transformer is working properly. It says to install the fuse and carefully apply power to the circuit (i have built a current limiting light bulb) and check the AC voltages are within range of spec.
I have not had a lot of experience using my multi meter, mostly I have checked my resistors. I have watched some videos on setting up my multi meter to measure AC but I am not sure how to proceed measuring on my amp (where specifically should I be placing my leads when doing the measuring). Also the instructions say the voltages will be higher with no tubes installed, how much higher is acceptable?
I have attached some pictures of what I have wired up so far.
Any advice/directions would be appreciated.
Cheers
Attachments: |
![IMG_2456.JPG](./download/file.php?id=1956&t=1&sid=7dc9376ef771fcb6e5c443fc5952abb0)
![IMG_2457.JPG](./download/file.php?id=1957&t=1&sid=7dc9376ef771fcb6e5c443fc5952abb0)
![IMG_2458.JPG](./download/file.php?id=1958&t=1&sid=7dc9376ef771fcb6e5c443fc5952abb0)
![IMG_2461.JPG](./download/file.php?id=1959&t=1&sid=7dc9376ef771fcb6e5c443fc5952abb0)
