It is currently Thu May 16, 2024 5:50 pm
PostPosted: Tue Mar 23, 2021 10:53 am
On my Tweed 5E3 kit wiring diagram, the white PT wire is soldered to the Neutral IEC plug with the black wire, correct? On the wiring diagram, it shows a Black/blue wire turning into the white wire. Is that Black/blue wire from another model of transformer?
PostPosted: Mon Dec 11, 2023 5:55 am
Based on the information you provided, it seems like you are referring to a specific wiring diagram for a Tweed 5E3 kit. However, as an AI text-based assistant, I don't have access to specific diagrams or schematics.
In general, when working with wiring diagrams, it's essential to follow the instructions and diagrams provided with your specific kit. The colors of wires can vary between different transformers and manufacturers, so it's crucial to refer to the documentation that came with your kit.
Fun Games is so easy
To ensure accuracy and safety, I recommend double-checking the instructions and diagrams provided with your Tweed 5E3 kit. If you have any doubts or questions about the specific wiring, it's always a good idea to consult with an experienced technician or the manufacturer for clarification.
PostPosted: Thu Apr 04, 2024 4:53 am
It is crucial to adhere to the instructions and diagrams supplied with your particular kit when dealing with wiring diagrams. Please consult the instructions that came with your kit since the colors of the wires may differ depending on the manufacturer and type of transformer you have. gorilla tag
