It is currently Thu May 30, 2024 5:50 pm
PostPosted: Tue Mar 23, 2021 2:48 pm
I'm at the stage of testing the power transformer on the 5E3 and I'm getting a reading of 94 Volts on each of the yellow wires soldered to the rectifier at pins 2 and 8.
It supposed to be reading 5 volts . Is it because the rectifier tube is not installed?
PostPosted: Fri Mar 26, 2021 2:59 pm
First thing comes to mind: Are you measuring DC or AC? Multimeter should be set for VAC. The other would be to check that Line to PT wiring is correct.
