It is currently Sun May 12, 2024 8:30 am
PostPosted: Tue Mar 30, 2021 12:06 pm
Just finished my 5E3 Trinity Tweed and it sounds great. However it has a hum that increases with the volumes increasing and crackles at 11 or 12.
I will try to post some photos and would appreciate any ideas you have on the problem.
PostPosted: Thu Jun 29, 2023 1:12 am
heave1 wrote:
Just finished my 5E3 Trinity Tweed and it sounds great. However it has a hum that increases with the volumes increasing and crackles at 11 or 12.bloxd io
Hi,
There could be several reasons why you are experiencing these issues. It could be due to a grounding issue or a problem with the tubes. You may want to try the following steps to see if they help resolve the issue:
1. Check the grounding of your amp. Make sure that all of the components are properly grounded and that there are no loose connections.
2. Check the tubes. Make sure that they are properly seated and that they are not damaged.
3. Check the wiring. Make sure that all of the wiring is properly connected and that there are no loose connections.
Users browsing this forum: Google [Bot] and 6 guests
