It is currently Tue Jan 20, 2026 9:47 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 21, 2012 11:10 am
I'm trying to find the thread about changing the bias resistor - maybe it was in the Tramp forum, I can go looking for it, but I just need to change the bias resister to set the range of bias correct?
I need to test my amp more to see if the problems that arise over time are heat, or oscillation related. There's definitely a problem when I engage the OD and turn it up past 7 (squealing) so there's room for improvement.
Thanks Stephen
PostPosted: Sun Dec 23, 2012 11:20 am
Seems to me the value was around 900K . Higher value means less current, so you may want to experiment.
PostPosted: Thu Jan 03, 2013 10:58 am
Since Christmas and new-year passed she finally got to play the damn thing haha.
I put the 6v6s in .. set the bias, and played for a couple hours although at fairly low volumes (0.5-1 on the master). Whatever problem I experienced at my jam-hall appears to be gone for now, but I didn't have it cranked ... so we'll see.
I am absolutely in love with this amp, and so is she! Really good compliment to her JCM800 because the glassy clean tones pick up every suitble nuisance of your pick/fingers. "I can hear ...everything!"
I think the best part is just how useable the EQ is - nothing gets harsh, you just get MORE of it. The presence knob actually feels like you're changing presence, not just boosting hights.
The OD channel is great, but with a modded ts-9 tubescreamer it adds distortion but also a low-fi quality that is really appealing. Paired it with two WGS Veteran 30 speakers and it sounds great.
Also, almost finished with the cab, although I have hardware to add and some more staining / design-burning to do on the front panel. The dovetails are roooough but I wanted the cab to look like it was made out of an old barn and set on fire. My partner likes post-apocalyptic type stuff.
Now, I realized after the fact that the 'official' cab has a vent - I figure the amp *should* be fine, unless is there something with this design that the tubes run super-dee-duper hot? I guess worst case I can leave the front panel off. But it completes it!
PostPosted: Thu Jan 03, 2013 5:36 pm
Looks great and glad it sounds great for you too. You should be OK without the top vent when running 6V6 with a good size rear panel cutout. Keep an eye on it. A cutout is not too hrd to retrofit in if required - I'd leave the front panel on.
Congrats on your success.
PostPosted: Fri Jan 04, 2013 5:47 pm
awesome, thanks! Yeah vent is pretty easy to add.
now I have the building bug.. you jerks!
PostPosted: Fri Jan 04, 2013 5:52 pm
what can we say. you built the "big daddy" first - now what?? :thumbsup:
PostPosted: Mon Jan 07, 2013 12:21 pm
haha now I build a clone of my main gigging amp. It's a Garnet Rebel PA that I've heavily modified, and if it ever dies on me completely I'll be forced to use my marshall JMP which .. I can't go back to.
got a couple other designs to mess up too :)
