It is currently Tue Apr 21, 2026 2:27 am
PostPosted: Sun Jan 08, 2017 3:49 pm
Hi guy's...
I made this video (10 minutes long) because I had problems with my build... not the case anymore.
Mitch M & Stephen were here on the forums to guide me to success.
https://www.youtube.com/watch?v=jddb51rptU8&feature=youtu.be
*This video was made while my amp was not 100% accurate. This was my first build and to finish it I went from 08:00PM to 08:00AM non-stop... (*not a good idea, that was just dumb and risking miss connection for nothing which happen 5 times *Thanks again Mitch for your patience*)
For the video, I made a clean loop and feed the signal to the amp via the 4 Cable method.
http://www.bossus.com/support/knowledge_base/201973789
*Nothing on, all sim disable on the GT-100...with the loop I was in patch edit mode which enable me to put some reverb, delay, chorus and play a bit with the wha at the very end of the video.*
*Note, this effect loop doesn't show on the order page, I had to contact Stephen via e-mail... he's so easy to get along!!!
Just for crap & giggle, these below were my reading on tube V4 at the time of the video
Supposed as per Layout test point / Actual (no bridge from pin 3 to pin 8 )
12AT7
P1: 274 / 214
P2: 67 / 74.2
P3: 74 / 76.7
P6: 236 / 411
P7: 64 / 37.7
P8: 74 / 87.0
PostPosted: Tue Jan 10, 2017 8:48 pm
Time to put a good you tube clip up there now!
PostPosted: Tue Jan 10, 2017 9:23 pm
I will as soon as I finish building the Head Cab...
the Triwatt handle the multi-effect pedal in the effect loop very well. It's the less tone invasive/soaking FX-Loop that I ever plug my gear in.
PostPosted: Wed Jan 11, 2017 12:24 am
Excellent feedback. This was the one straight out of the documentation?
