tom_c wrote:
Overdrive does nothing at all, but I've worked out there is a wire missing which isn't shown on the layout for the relay board driven off the heater wires, namely the one from Pin 1 of the overdrive pot. It makes complete sense that it is needed, but perhaps an update to the documentation to show it?
Is this the layout you are using?
From here:
https://www.trinityamps.com/wp-docs/TRI ... ual_3V.pdf
