It is currently Fri May 09, 2025 1:36 am
 Post subject: Which NOS tubes preamp?
PostPosted: Wed Sep 06, 2023 1:10 pm
Hi all,
Any advice on which NOS tubes to put where in the preamp?
Got a Mullard long plate F92 and some I63 and I61's
Just curious, what is the exact function of each slot and what will NOS tubes yield in those positions?
V1 -> first gain stage, right? Most important?
V2 -> second gain stage. Is this only used when the OD channel is engaged? I believe half of it is only used when the OD is engaged here. Can somebody confirm?
V3 -> what is the function of this slot?
V4 -> PI of course. Second most important, right?
Looking forward to your experiences. Thanks!
PostPosted: Mon Dec 04, 2023 2:49 am
Gertjan2411 wrote:
Hi all,
I also want to learn about this topic, but don't know much, hope to learn more information here
connections
PostPosted: Mon Feb 05, 2024 9:50 am
NOS stands for New Old Stock, and it refers to vacuum tubes that were made decades ago but never used. Some audiophiles and musicians prefer NOS tubes over modern ones, because they believe they have better sound quality, durability, and reliability.
The function and importance of each slot in your preamp depends on the type and model of your amplifier, as well as your personal preference and taste. However, here are some general guidelines that may help you:
• V1: This is the first gain stage, and it is usually the most important for shaping your tone. It amplifies the signal from your guitar or other input source, and it affects the amount of distortion, clarity, and dynamics. A good NOS tube for this slot would be a Mullard long plate F92, which is known for its warm, rich, and smooth sound. It has low noise and microphonics, and it can handle high voltages well.
• V2: This is the second gain stage, and it is usually used for the overdrive or distortion channel. It adds more gain and saturation to the signal, and it affects the character and intensity of the distortion. Half of this tube is also used for the reverb circuit, if your amp has one. A good NOS tube for this slot would be a Mullard I63, which is similar to the F92, but has a shorter plate and a different getter. It has a more aggressive and crunchy sound, and it can produce a nice reverb effect.
• V3: This is the third gain stage, and it is usually used for the tone stack or the equalizer. It shapes the frequency response of the signal, and it affects the balance and color of the bass, mid, and treble. It also acts as a buffer between the preamp and the power amp. A good NOS tube for this slot would be a Mullard I61, which is a low-noise and low-microphonic tube. It has a clear and balanced sound, and it can preserve the tone and dynamics of the signal.
• V4: This is the phase inverter, and it is usually the second most important for your tone. It splits the signal into two opposite phases, and it sends them to the power tubes. It affects the power, headroom, and feedback of the amp. A good NOS tube for this slot would be another Mullard I61, which can handle high currents and voltages well. It can also create a symmetrical and harmonic distortion, which can enhance the tone and feel of the amp.
retro bowl
PostPosted: Tue Sep 17, 2024 11:35 pm
Choosing the best NOS (New Old Stock) tubes for your Pokerogue preamp depends on your desired tonal qualities, the type of music you play, and the specific preamp you are using.
PostPosted: Fri Apr 11, 2025 5:53 am
V1: This is indeed the first gain stage and is crucial for shaping your overall tone. Using a high-quality NOS tube here can enhance clarity and warmth.
V2: Correct, this is the second gain stage. It typically handles the clean channel, while part of it may engage with the overdrive channel.
V3: This slot often serves as a tone control or additional gain stage, depending on your amp's design.
V4: As the phase inverter (PI), this is critical for driving the power tubes, making it the second most important slot. A good NOS tube here can improve dynamics and response.
I think so :happydance: slope
