It is currently Mon May 19, 2025 1:45 am
 Post subject: Tweaker notes
PostPosted: Thu Jan 23, 2020 8:05 pm
Hello Stephen, I was looking at the tweaker notes and in the schematic you have "see tweaker notes" on V3 pin 8. But when you look at the notes it says V2 pin 3. we want to explore some of these sounds and was checking on which is correct.
Thanks Mark
 Post subject: Re: Tweaker notes
PostPosted: Thu Jan 23, 2020 8:19 pm
Oh and another thing. on the 64uf,100uf,150uf and the 47nf what type of cap should they be and what should the voltage rating be?
thanks
PostPosted: Thu Jan 23, 2020 9:09 pm
As you said, there's nothing mentioned about the tweak to V3 pin 8 on the schematic, but the builder's guide says this about it:
Optionally remove the 47n bypass cap on V3 pin 8. Removing the cap would reduce a fair bit of post-MV gain, as well as increase bass, but may not be to the liking of those folks who would want a Triwatt for its earlier breakup compared to a DR.
The other tweaks are in the cathode circuits of V1 and V2. The voltages there are really low, about 1 or 2 volts. You can use capacitors rated for 50 volts or higher, just to give it a good safety margin. The 64uF, 100uF, and 150uF are electrolytics. The 47nF can be the same as C1.
PostPosted: Thu Jan 23, 2020 9:26 pm
that is what I was looking for
thanks
Mark
PostPosted: Tue Feb 18, 2025 2:35 am
Monkey Mart Game
What impact does removing the 47n bypass capacitor on V3 pin 8 have on the overall tone and gain structure of the amp, and how does it compare to the stock configuration in terms of breakup and bass response?
PostPosted: Thu Mar 06, 2025 10:06 pm
I was reviewing the tweaker notes and noticed a discrepancy in Geometry Dash the schematic. The schematic references "see tweaker notes" on V3 pin 8, but when checking the notes, it mentions V2 pin 3 instead.
We’re interested in exploring some of these sounds and wanted to confirm which reference is correct. Could you please clarify?
Thanks in advance!
