It is currently Tue Jan 20, 2026 6:06 pm
PostPosted: Sat Feb 14, 2009 12:29 pm
This is the current board design. It is a departure from the other boards we've made in that there are no angled component placement.
I tried to keep some Hiwatt Mojo going on this one!! 8) There are about 20% more turrets just due to the rectalinear design. All turrets of course.
Ground buss will be copper bar on top.
Tried to minimize the under board jumpers too, but there are still a few left.
Note polarities of caps in this layout are added. Thanks zaphod!
[img]Image%20Moved%20to%20Resource%20%20Fourm%20-%20TRIWATT%20Docs[/img]
PostPosted: Sat Feb 14, 2009 3:05 pm
No shortage of parts on this one :shock:
What's it like for you experienced guys building and debugging this amp mirrored from the typical 15's, 18's and Deluxe?? This will be like my rackmount V6 with the inputs on the left facing it!
Looks very cool guys 8)
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Sat Feb 14, 2009 3:46 pm
Yes, this amp has the same number of preamp stages as a SLO or Meza DR :shock: And yes, there's quite a lot of work in one of these. However, if you just stick closely to the layout we will publish, and keep your wiring nice and tidy, you shouldn't have any problems. The TRIWATT is a surprisingly well-behaved amp. :D
PostPosted: Sat Feb 14, 2009 4:31 pm
WE'll confirm the layout with the next build and then publish the details.
If you've built an 18 watt you should be OK. Complexitiy is a bit more than a TC-15 and it is fixed bias so that's different too for some.
Plus if you get in one the first batch, there will be a lot of builders posting!!
PostPosted: Sun Feb 15, 2009 3:09 pm
Looking forward to the "final" details :P :P :P
PostPosted: Sat Mar 14, 2009 7:26 pm
Image Moved to Resource Fourm - TRIWATT Docs
