It is currently Tue Jan 20, 2026 12:13 pm
 Post subject: Triwatt in Oakland!
PostPosted: Fri Jul 03, 2009 3:49 am
Hello and guess what I did? Bought the kit and built it. The build went very well and upon start -up I only had a few issues which I was able to fix. Ground wire to bias pot I missed, small jumper between pins of the bass pot. It is very quiet and most of my voltages look very close but I am going to post in a day or two. Transformers did not get hot.
The bias seems to be just as high as a 6V6 tube should be, but no higher. The sweep of the bias pot to one end just gets to 25 mvdc. I actually had it switched on the little toggle for setting KT66 tubes but it did not bias high enough for 6V6, only to 13 mvdc.
Okay so it is night and I can't play loud till tomorrow but I was curious about a few things:
How can a 6V6 amp sounds so clean? And loud?
I can tell this is going to be a fun amp! I have two 1x12 cabs one is a Scumback M75 30 watt 16 ohm and the other is a G12H 30 watt speaker. I also have a 2x10 cabinet with two Tone Tubby ceramic 40/40 . I think that will be a fun one!
I will post some pictures in a few days. This is a great amp.
PostPosted: Fri Jul 03, 2009 7:36 am
Congrats! Sounds like a pretty smooth build. Hope to hear some clips soon!
J.
PostPosted: Fri Jul 03, 2009 10:08 am
Hank, welcome and congrats :D I just finished mine up last weekend :D :D
I have the exact same bias issue as you do :?
On the 6v6 setting, bias pot adjusts from 3.0mV to 11.0mV
On the KT66 setting, bias pot adjusts from 10.4mV to 23.3mV
Mains voltage is 116.8VAC
What is your voltage at the following nodes?
Junction of D6/R45/C22, schematic says should be -54VDC, I have -50.3VDC
Junction of R45/R46/C23, schematic says should be -45VDC, I have -39.6VDC
Enjoy your amp :D :P :D :P
PostPosted: Fri Jul 03, 2009 9:51 pm
The good news is you can get the 6V6 to bias to 20ma. The bad news is, 20 ma should be about mid-range on the dial. Can you confirm your bias range resistors values please? 620K & 180K?
PostPosted: Sun Jul 05, 2009 9:37 am
if it only went up to 13mV, then that was the KT66 setting.
Hank S wrote:
How can a 6V6 amp sounds so clean? And loud?mI can tell this is going to be a fun amp! I have two 1x12 cabs one is a Scumback M75 30 watt 16 ohm and the other is a G12H 30 watt speaker. I also have a 2x10 cabinet with two Tone Tubby ceramic 40/40 . I think that will be a fun one! I will post some pictures in a few days. This is a great amp.
Glad you like the amp!!! :D
It's actually the other way round. The 6V6 setting gives the higher current. Toggle switches have a way of confusing people, since the contacts that get closed are opposite to the direction the toggle is pointing in.
PostPosted: Sun Jul 05, 2009 11:16 pm
Well then I must say this is working great!. I will post a picture soon and I have ordered Shuguang KT66 and Tung-Sol 12AX7 and I have a JJ 12at7 in v4 right now. I really can't believe this amp! It is so clean and feels more clean than a 50 watt plexi and a 40 watt fender amp in the headroom department.
Now when I read that the KT66 doesn't fit in here if it is in a regular Marshall like head cabinet I wonder if the tubes will fit but there is just a fire hazard? Maybe just need a vent above the tubes?
Thanks guys.
PostPosted: Mon Jul 06, 2009 7:39 am
Funny - I discussed that very thing with Stephen when ordering my head cab. The Triwatt cab is vented in the top for this very reason! As for the fit, the chassis does have to be removed to fit the KT-66's from what I understand.
PostPosted: Mon Jul 06, 2009 8:35 am
Yes, you have to be very careful of the inside height so you can remove a KT66 without removing the chasssis. Dont forget ! I will fit inside a JTM head inside height.
Clean yes, and you have the OD as well .
Glad you're liking the amp. Any tips you discover?
Put 'em here: viewtopic.php?t=169'
 Post subject: Re: Triwatt in Oakland!
PostPosted: Fri Oct 21, 2011 5:54 pm
So after enjoying my Triwatt for a while I sold like I do with most of the amps I build. Not suprising. But now I'm going got get it back! I have been in contact with the person who has it and we are wirking out a trade deal.
After getting it back I may put an effects loop in it. Has anyone done that? I like the Iron Sounds loop a lot. Used it in a Brown Note D'lite.
PostPosted: Mon Oct 24, 2011 10:12 pm
o
That may be a first! Good move! Let me know on the IS Loop. Always thought it would be nice to havethat option if it works out.
PostPosted: Tue Nov 08, 2011 11:42 pm
Space is pretty tight in there, and with the high preamp gain levels the Triwatt has, I'd be nervous about doing that. There's a fair risk that you would get noise and oscillation problems. OTOH it would br pretty easy to insert a passive series loop, either just before or right after the MV. The extra preamp stage after the MV makes for a useful recovery stage. One of the nice features of the Hiwatt design. :)
