It is currently Tue Jan 20, 2026 1:09 pm
 Post subject: Help with control wiring
PostPosted: Mon May 23, 2011 1:21 am
Hello all,
I started a Triwatt build and am unsure about the correct wiring of some of the variable resistor control pots.
1. On the 500K Bass pot, it looks like there is a jumper between terminal 1 and terminal 2. Is this correct?
2. On the 100K Middle pot, it looks like the 22K resistor terminates on terminal 2 and there is a jumper between terminal 2 and terminal 1. Is this correct?
Thank you for any help.
PostPosted: Tue May 24, 2011 8:54 am
1. Yes that's correct.
2. Yes that's correct
When in doubt always refer back to the schematic.
PostPosted: Tue May 24, 2011 10:04 am
Thanks Zaphod. I appreciate your help and always look forward to your responses on this forum.
