It is currently Tue Jan 20, 2026 12:02 pm
PostPosted: Sun Nov 11, 2012 5:37 pm
Hi,
Just finished wiring up my Triwatt build this evening. I don't have any tubes (and probably won't for a couple of weeks) - is it safe to perform the 1 second pilot lamp test at this point without tubes - plug amp in, flip the switch to standby for 1 second to check lamp comes on, then immediately back to off again?
PostPosted: Sun Nov 11, 2012 7:32 pm
Yes
That is fine, you can do that and more but stick with the pilot lamp test for now.
PostPosted: Mon Nov 12, 2012 11:55 am
First test looks good- the lamp came on without any surprises occurring.
After having done this 1 second lamp test (switch to standby only then off again), do I need to worry about caps having stored lethal voltages from this test if I need to poke around in there still?
PostPosted: Mon Nov 12, 2012 12:32 pm
As long as you installed the 220k (bleeder) resistors on the cap cans the caps will discharge.
