It is currently Tue Jul 16, 2024 8:40 am
 Post subject: Cab for the Triwatt.
PostPosted: Tue Dec 31, 2019 10:04 pm
We where going to order a kit from Stephen, but 2 weeks ago we had the chance to buy a built Triwatt from a fellow through Kijiji.
Beautiful amp. Has the KT66’s.
thanks to Stephen for sending the drawing.
Built the head cab today.
Tolex on order.
 Post subject: Re: Cab for the Triwatt.
PostPosted: Wed Jan 01, 2020 9:59 am
So the one you bought is working fine then. From Garett? The Triwatt cab also has a vent on top for cooling.
PostPosted: Wed Jan 01, 2020 1:23 pm
Yes, it seems to be working fine. Through conversation with Garett, I think he has made at least 3 different Trinity kits. We have ran it quite a bit over the holidays, without any problems.
We noticed the top venting in the drawing, my son thought we would see how much heat it would produce.
I think better to have more venting, I'll persuade him to go with venting in the top.
Is grill cloth ok for vent covering, or should go with some kind of painted screen?
Scott
PostPosted: Wed May 06, 2020 10:45 pm
Finally got the Tolex on today.
First attempt. Went ok. I’m sure then next will be easier, & find a couple tricks that would make it easier.
Speaker cab next.
Scott
PostPosted: Thu May 07, 2020 12:07 am
Looks good, Scott. You picked a tough cabinet for your first Tolex job. With the compound radius corners, the piping, and the vent, installing Tolex on a cabinet like that can be challenging.
