It is currently Tue Apr 21, 2026 2:23 am
PostPosted: Fri May 19, 2017 10:47 am
When I engage the overdrive it has quite a bit of noise past 3 o'clock or so, not surprising for overdrive, but I thought I'd see if it's normal for this amp.
Couple more quirks.
I find it difficult to switch to the overdrive, to get the crunch I want the overdrive has to be quite a ways up, but at that level when I engage it there's a huge volume boost -- what settings Normal, Bright, Master and Overdrive allow for an overdrive sound that's switchable without the massive volume boost?
If Bright volume is too low and overdrive engaged I get squealing, anyone else?
http://amparchives.com
PostPosted: Thu Nov 23, 2017 12:00 pm
Wire dressing is most likely cause of squealing. Use a straight wire as shown in the layout from term strip to pull pot.
