It is currently Sat Aug 22, 2026 3:39 pm
 Post subject: Lead free silver solder
PostPosted: Sun Sep 13, 2020 8:53 pm
I mostly have lead free rosin core silver solder on hand. Is there any reason not to use this? I make guitar pickups and cables and prefer the silver bearing solder.
I appreciate the help
Kev
PostPosted: Tue Sep 22, 2020 3:26 pm
I typically use WBT 4% Silver solder, almost impossible to create a bad connection. Great flow too. So, no reason that I know of.
PostPosted: Sun Sep 27, 2020 7:10 pm
Should be fine to use! How are things progressing with your build?
PostPosted: Tue Oct 06, 2020 5:55 pm
The build is going great, slowly and carefully. Trying to figure out the orientation of Mallory capacitors without an o-scope.
PostPosted: Thu Oct 08, 2020 6:10 am
Great to hear that your build is going well.
Just keep it slow and steady. That's the way to go! :D
Let us know if you need any assistance!
PostPosted: Sun Oct 11, 2020 5:51 pm
Hello, it's such a pleasure to greet you, I'm glad your construction goes very well, don't worry about how slow it is, the important thing is that everything is looking good, it would be great if you show us the progress through photos, thanks :thumbsup:
http://www.seoplanner.com/
PostPosted: Mon Oct 12, 2020 3:09 pm
I powered through a lot of the build this week. I’m almost ready to start connecting the boards to the amp. My plan was to use the 6.3 v at v1 to run power to the overdrive and the tube effects loop.
PostPosted: Wed Jan 20, 2021 4:46 pm
WBT 4% silver solder or Mundorf !
