It is currently Wed Jun 10, 2026 11:53 pm
 Post subject: Noob Advice. KT66 Bias
PostPosted: Sat May 21, 2022 12:50 pm
OK, so I just picked up a used Triwatt and it came loaded with KT66s. I played with it for a while and was not impressed at all. It was brittle and had no guts at all in any channel input. So to satisfy my curiosity I opened it up to see the tubes and check if anything was obviously burnt out (I AM NOT AN AMP TECH). What I found was the power tube switch was set to 6v6. Obv not a good thing. I switched it to KT66 and some life came back to the amp. More bottom and a fuller range of sound were evident. But, it's still not very loud at all. I am now thinking maybe the bias is off? I would love to check myself and save myself the trip and tech fees. I have a multimeter but I have no idea how to do this or how to adjust? Is this crazy? Let me know.
PostPosted: Sat May 21, 2022 3:04 pm
I have my bias set at 35ma when running KT66. My Triwatt is seriously loud. Cranked, I can’t be in the same room with it. Lol There are bias test points on the rear of the amp. The black one Is the ground the two red ones read one tube at a time. There is a trim pot above the black socket that you put a screw driver in to adjust the bias. It’s very important to have that switch set to the KT66 setting. If your tubes start glowing cherry red, they’re red plating and are under biased and are getting too much voltage. The Triwatt is a great sounding amp with KT66 output tubes.
PostPosted: Sat May 21, 2022 5:19 pm
Thanks for the guidance Brodie!
I am on it.
PostPosted: Sat May 21, 2022 8:35 pm
No problem. I hope it helps.
PostPosted: Sat May 28, 2022 3:43 pm
It was a huge help. It's all dialed in now and now the amp, along with all of my pedals, just sound better.
PostPosted: Thu Dec 05, 2024 2:58 am
To adjust the bias on your Triwatt amp, I suggest using a multimeter to measure the current flowing through the KT66 power Block Blast tubes, typically at a test point on the chassis or with a bias probe.
PostPosted: Sun Feb 16, 2025 10:22 pm
It's great that you're taking initiative to troubleshoot your amp! Biasing checks are crucial for tube amps. You'll need to measure the cathode voltage and grid voltages. Be cautious, as tube amps can be dangerous if not handled properly. If you're not experienced, it might be best to sprunki consult a tech. But if you're up for it, there are many online guides that can walk you through the process. Good luck!
Das Leben ist nur ein Spiel, aber ich werde es ernst nehmen und niemals davonlaufen
PostPosted: Sat Feb 22, 2025 10:42 pm
For the purpose of adjusting the bias on your Triwatt amplifier, I suggest employing a bias probe or a multimeter to measure the current flowing through the KT66 power Golf Orbit tubes, typically at a test point on the chassis.
PostPosted: Fri May 16, 2025 2:10 am
Interesting find with that Triwatt! Sounds like you've already diagnosed a key issue switching from 6V6 to KT66. It's great you noticed that yourself. If you're feeling adventurous and want to dive deeper, maybe explore online resources related to biasing amps with KT66 tubes. Think of it like strategizing your next Pokerogue and Pokerogue Dex move. You wouldn't go in blind, right? Just like you'd consult the Pokerogue Dex for the best type matchups, research biasing carefully before you proceed. A little knowledge can save you a lot!
