It is currently Tue Jul 28, 2026 11:06 am
 Post subject: Dead Triwatt?
PostPosted: Sat Aug 23, 2025 11:59 am
I rebiased my Triwatt for kt66s a few months ago and have been loving the change.
I played a gig last Saturday - no issues.
This morning I plugged in the amp and it made a squeaky whine sound, the audio got weak and then everything went dead.
I did smell an odor of electrical burn but there was no smoke or fire.
I thought maybe I had blown a fuse, so I pulled it and it had continuity. So, no problem there.
But the amp is totally dead. No Power at all.
I have tried three IEC cables and as many outlets.
I pulled the chassis and see no signs of damage.
Any idea where to start troubleshooting?
 Post subject: Re: Dead Triwatt?
PostPosted: Tue Oct 14, 2025 5:05 am
Make sure the power switch itself is functioning. Sometimes, switches can fail internally. If you have a multimeter, you can test continuity through the switch when it’s in the "on" position Head Soccer. If no continuity is detected when the switch is on, the switch itself may be faulty.
PostPosted: Mon Jul 27, 2026 11:13 pm
Hey there! I totally relate to the frustrations of troubleshooting amps. I once had a similar issue with my old tube amp, and it turned out to be just a loose wire! Glad you’re working through this—best of luck! granny 1
