It is currently Thu Apr 16, 2026 5:32 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 06, 2011 12:07 pm
Check your 6V6/6L6 switch, it looks like your missing a bridging connection.
For no signal...
- check your jumpers
- coax (shorting the inner core (signal) and shield (ground) is very common)
- check your wiring, mainly around pots and tube socket.
Chris...
Orange and blue wire, should be bridged.
PostPosted: Mon Mar 07, 2011 3:50 pm
I wasn't at the Tramp Camp, but I have one or two spots I had to fix before mine worked.
First, I had the zener diode backwards.
Second, I had to jumper both center lugs of the impedence switch to get my amp to work.
