It is currently Tue Apr 07, 2026 8:14 pm
 Post subject: MOSFET damage???
PostPosted: Sun Nov 06, 2011 8:43 am
How can you tell if it was damaged before you install it?
 Post subject: Re: MOSFET damage???
PostPosted: Thu Nov 10, 2011 8:47 pm
Testing a MosFet
This testing procedure is for use with a digital multimeter in the diode test-range with a minimum of 3.3 volt over d.u.t. (diode-under-test)
Connect the 'Source' of the MosFet to the meter's negative (-) lead.
1) Hold the MosFet by the case or the tab but don't touch the metal parts of the test probes with any of the other MosFet's terminals until needed.
2) First, touch the meter positive lead onto the MosFet's 'Gate'.
3) Now move the positive probe to the 'Drain'. You should get a 'low' reading. The MosFet's internal capacitance on the gate has now been charged up by the meter and the device is 'turned-on'.
4) With the meter positive still connected to the drain, touch a finger between source and gate (and drain if you like, it does not matter at this stage). The gate will be discharged through your finger and the meter reading should go high, indicating a non-conductive device.
Such a simple test is not 100% -- but is useful and usually adequate.
PostPosted: Sat Nov 12, 2011 4:48 pm
Is there a way to perform this test on a MOSFET that is already installed, perhaps by disconnecting a minimum number of connections, or would it need to be completely removed from the chassis and circuit?
