It is currently Mon May 06, 2024 2:56 pm
PostPosted: Sun Jan 09, 2022 1:01 pm
Does anybody know that size female spade connector fits properly on a tone tubby red 10" speaker?
And what size wire gauge crimps properly? I looked at making my own by cutting a speaker cables with 1/4 plugs in two. The Daddarios cable is typical, constructed with 16 AWG wire. THe female 0.205" connectors are specified to use 18-22 AWG wire, a little tight for a 16 Gauge. Do I just snip off some of the strands to make it fit?
The cable:
https://smile.amazon.com/gp/product/B00 ... 0DER&psc=1
Connector kit:
https://smile.amazon.com/gp/product/B07 ... 750L&psc=1
Or alternatively, is there something off the shelf that goes from the 1/4 jack in the head to the speaker lugs in the cabinet?
Thank you all,
Peter
PostPosted: Sun Jan 09, 2022 10:11 pm
I had the same question regarding spade connectors a while back, and came across this at WGS. I ordered some and they work like a charm for every speaker I've used.
https://wgsusa.com/proper-size-speaker- ... ive-answer
As for the wire gauge, I suppose that depends on how long the run is to the cab. Short runs (combos, a few feet) you can probably use 20AWG no problem, even with a 50-100W head. Longer runs may require heavier gauge. But once you arrive at the cab, you can use smaller gauge.
Looking inside a Marshall 4x12 cab you will probably see 20AWG wire going from the jacks to each speaker.
PostPosted: Wed Jan 12, 2022 7:24 am
I ended up buying
1. a 16AWG speaker cable: https://smile.amazon.com/gp/product/B00 ... =UTF8&th=1
2. an assortment of 14-16 AWG female spade connectors: https://smile.amazon.com/gp/product/B07 ... UTF8&psc=1
As the article noted by PharmRock above indicated, the 0.205" ones fit well. The fit is snug and they can be removed. I think the real challenge will be getting the amplifier working. I checked every connection multiple times. But despite my best efforts, it's been difficult to avoid the sixth grade sicience fair style in some of the wiring.
PostPosted: Wed Jan 12, 2022 2:13 pm
Have you powered on the amp yet? What type of problems are you encountering?
PostPosted: Fri Jan 14, 2022 7:20 pm
Powering it up is the project for the weekend. For now, I'm studying the startup guide and thinking it through. I'm getting pretty eager though...
PostPosted: Fri Jan 14, 2022 8:46 pm
I highly recommend getting a light bulb limiter. It adds an "extra layer of protection" on start-up, and is a great visual cue if something is going or about to go wrong. Decreases likelihood of blowing a fuse, and more importantly, helps protect the transformers.
https://robrobinette.com/Tube_Amp_Startup.htm
PostPosted: Sun Jan 16, 2022 6:44 pm
It's working! Sounds great!!!!
Took a little troubleshooting.
PostPosted: Mon Jan 17, 2022 1:58 am
:thumbsup: :D
PostPosted: Thu Nov 23, 2023 3:47 am
:hmmm: :hmmm: :hmmm: :thumbsup: :D
only up
PostPosted: Tue Dec 26, 2023 12:12 am
RosenTube wrote:
I ended up buying
1. a 16AWG speaker cable: https://smile.amazon.com/gp/product/B00 ... =UTF8&th=1 subway surfers
It worked. Many thanks!
PostPosted: Fri Feb 23, 2024 12:49 am
https://robrobinette.com/Tube_Amp_Startup.htm geometry dash lite
Thanks for your suggestion, where should I buy it
