It is currently Sat Aug 31, 2024 6:54 pm
PostPosted: Wed Nov 15, 2023 3:21 am
Hello,
would the installation of an effect loop be possible on a Tramp amp?
(Apologies if this question has been posted before)
A very happy Tramp owner ;-)
PostPosted: Sun Feb 25, 2024 11:40 pm
Although the thread is quite old, I still want to answer because it seems that nobody cares.
The Tramp amp does not have an effect loop built-in. However, it may be possible to install one by modifying the circuit of the amp. This would require some technical skills and knowledge, and it may void the warranty of the amp. Therefore, it is not recommended to do it yourself, unless you are confident and experienced in amp modification. You may want to consult a professional amp technician or builder for advice and assistance. geometry dash
Alternatively, you may consider using a different amp that has an effect loop, or using pedals that work well with the front end of the amp. The Tramp amp is designed to have a vintage-style tone and response, and it may sound better with pedals that are compatible with its character and headroom. You can experiment with different pedal orders and settings to find the best sound for your amp.
PostPosted: Sun Apr 21, 2024 11:56 pm
pixel speedrun said:
Hello,
A big part of the Tramp's sound comes from the interaction between the preamp and power amp sections. Placing effects in a loop (between these sections) might not be much different than putting them before the input, particularly if you're aiming for power tube distortion.
Consider external pedals. If you're looking for reverb or delay, pedals can provide those effects without modifying the amp. A DI box can help integrate pedals with the Tramp.
PostPosted: Tue Jul 23, 2024 5:53 am
An effect loop is a way to route audio FNF signals through external effects processors or pedals.
