It is currently Thu Apr 16, 2026 9:18 pm
 Post subject: NOS 6V6 in Tramp
PostPosted: Tue Sep 21, 2010 7:59 am
Just curious if it is save to try some NOS 6V6's in the Tramp. I heard that some Champ variants run a hot bias on the 6V6 and may damage NOS tubes. Just want to make sure before I try.
Thanks in advance.
 Post subject: Re: NOS 6V6 in Tramp
PostPosted: Tue Sep 21, 2010 10:55 am
The Tramp runs 6V6s at no more than their safe-rated maximum dissipation of 14W. However, also be aware that it runs them at up to 420V with the VVR/VRM turned all the way up. This is also no problem with most NOS tubes. However, I might hesitate to try the real old style "coke bottle" or metal-can 6V6s in a Tramp.
PostPosted: Tue Sep 21, 2010 11:10 am
I figured since it only has 2 tubes it is a prime candidate for trying some premium NOS tubes without breaking the bank.
I've got one of these on order:
Bendix 5992 "Red Bank" 1950's
Probably going to pair it up with a NOS RCA 12AX7
PostPosted: Tue Sep 21, 2010 2:05 pm
Should be a rockin' robin! You might keep a watch on the tube and may want to turn the VRM down if you think it's a little too hot.
PostPosted: Tue Sep 21, 2010 3:00 pm
Thanks. I like the VRM around 7 anyway so it should be safe.
PostPosted: Tue Sep 21, 2010 5:49 pm
Yeah, then no problem.
Users browsing this forum: Google [Bot] and 1 guest
