 Post subject: Close, but no cigar yet
PostPosted: Sat Mar 05, 2011 12:22 pm
Going through the power up, got to the point of installing tubes and measuring DC at the second 50 µf cap + terminal. With VRM at idle I get 440.5 VDC (120.1 VAC supply). When I turn the VRM up, the voltage drops rather than rising, to 395 at max VRM.
The wiring of the VRM pot looks OK according to the layout.
Suggestions?
PostPosted: Sat Mar 05, 2011 12:25 pm
Measure the voltage as you turn the VRM at the first filter cap. It should vary there from (sub 100V) to around 400V.
PostPosted: Sat Mar 05, 2011 12:33 pm
That looks better - I get 392 VDC at max VRM. Good to go to the next step?
PostPosted: Sat Mar 05, 2011 12:43 pm
Sounds good,
on to the next step.
PostPosted: Sat Mar 05, 2011 12:46 pm
Cool.
I'm not seeing where to measure B+ in the next step. The build manual says to measure at the 50 µf cap R8/C6 connection. Could you point me at this connection?
PostPosted: Sun Mar 06, 2011 1:02 am
You measure (real carefully) at the positive terminal of that cap - ie the terminal that isn't connected to ground.
