It is currently Thu Apr 16, 2026 9:18 pm
PostPosted: Thu Mar 31, 2011 3:04 pm
Hi folks,
I'm getting the itch to build another Tramp (sold mine to my cousin if you remember).
Has anyone toyed with the idea of adding a second pre-amp tube for additional cascaded gain stages? I'm looking for ideas on how to implement something like that as a switchable option.
Your thoughts?
Kirb
SG + Brit tube head = Nirvana
PostPosted: Fri Apr 01, 2011 8:29 am
Interested? You bet!!
If you set it up as a cathode follower and eliminated the tone stack loss, it would gain the amp up and crunch it out!
Go here for a lot of similar dicsussion: viewtopic.php?f=2&t=1422
You might be able to borrow from The High Octane Amp 3rd gain stage / cathode follower design.
http://www.ax84.com/static/hioctane/AX8 ... 101004.pdf
PostPosted: Fri Apr 01, 2011 12:43 pm
Thanks Stephen. I'll check it out.
Users browsing this forum: Google [Bot] and 1 guest
