It is currently Thu Apr 16, 2026 8:23 pm
 Post subject: blowing fuses
PostPosted: Tue Jun 21, 2011 9:39 am
blowing fuses in my tramp.I will go over the layout and check all connections.How can I bypass the vrm to see if that is the problem?
 Post subject: Re: blowing fuses
PostPosted: Tue Jun 21, 2011 12:22 pm
Guys, start by shorting out the VRM. We need to eliminate that from the equation and first get the main part of the amp working. Solder a shorting wire from the VRM end of 100 ohm resistor R23 to the + end of the second filter cap C12.
With the VRM out of the way, you should have a nice loud amp. We can deal with the VRM later.
This is from
viewtopic.php?f=16&t=2575
Tele's make the best noise
PostPosted: Fri Jun 24, 2011 5:56 pm
did you ever get yours fixed? was the VRM the issue?
PostPosted: Sat Jun 25, 2011 5:44 am
I have to get some fuses today,found a jumper missing. continuity checks out now. I will post results.
