It is currently Wed Apr 08, 2026 10:40 am
 Post subject: VRM woes
PostPosted: Sun Sep 25, 2011 1:47 pm
After shorting out the original MOSFET while attempting to take measurements, I installed a new one I got from Stephen (I grounded myself to eliminate static before handling). Initially the sound level was varying up and down on its own. I switched the amp off to try swapping tubes, and when powered up again the VRM was not functioning.
Any ideas?
Could I have over-heated the MOSFET leads when soldering?
 Post subject: Re: VRM woes
PostPosted: Mon Sep 26, 2011 2:16 am
Interested about this also. Just attempted to fire up my tramp yesterday and I'm not getting the 400V on the first filter cap so I'm thinking MOSFET damage. I haven't seen this mentioned before - what is the actual procedure for grounding your body? Is an anti-static wristband the way to go? Because I don't have a wristband, I just kept one hand on the chassis while touching the MOSFET, but I'm thinking the chassis wasn't really grounded since it wasn't plugged in to the mains.
PostPosted: Mon Sep 26, 2011 8:36 am
I guess a better description would be "discharge any static" in your body by touching a ground, like a copper water pipe. You don't need to be continually grounded, in fact it's preferable to be isolated from ground when working with high voltage.
PostPosted: Thu Sep 29, 2011 9:20 pm
We say "Note: Ground your body before handling the MOSFET.
Touch a waterpipe or some other such ground source.
These are tough industrial MOSFETS that can take a little beating and some mishandling.
PostPosted: Thu Sep 29, 2011 10:05 pm
How can I test the MOSFET to see if it's dead or alive?
