It is currently Tue Apr 07, 2026 11:21 pm
 Post subject: Bias switch confusion
PostPosted: Wed Mar 09, 2011 4:19 pm
The build diagram shows the 6V6 as down and the 6L6 as up on the bias switch. I am using a KT66 which required no mods to the stock build. When I left Amp Camp we had the switch in the down position (towards the bottom of chassis) and the KT66 worked just fine. If I am substituting the 6V6 do I need to switch the bias? I ask this because I tried the 6V6 and saw the tube heating very quickly (perhaps too quickly). Also there was some noise so I shut down quickly with no damage done. That left me wondering if the KT66 and 6V6 use the same bias position.
PostPosted: Wed Mar 09, 2011 4:39 pm
Yes the bias switch is for either a 6V6 or 6L6(Kt66). IOW, yes you must throw the switch when changing from 6v6 to 6l6(Kt66).
PostPosted: Wed Mar 09, 2011 5:22 pm
What happens if you mix up the positions? I assume the KT66 would run cold and sound like crap and the 6V6 would run hot and blow up. Any damage to components other than the tubes?
PostPosted: Wed Mar 09, 2011 6:15 pm
That the 6V6 will run hot and possibly red plate and the KT will run cold.
Un plug the amp and let the B+ die off. Pull the o/p tube out and put the + lead of you ohm meter into pin #8 and the other lead to ground and after letting the big cap charge up you should get a ohms reading of about 750 ohms for the 6V6 setting and about 325 Ohms for the 6l6 setting.
Stew
PostPosted: Sat Nov 05, 2011 7:40 am
So to be clear: when behind the amp pushing the switch towards the speaker is 6V6 and back towards yourself 6L6/KT66 correct?
