 Post subject: Tramp build
PostPosted: Sun Mar 10, 2013 2:39 pm
Turning on for the first time , going thru the start up procedure, good until I put in the tubes , speaker , no voltage on the second 50uf cap on the + terminal . With my fluke 112 meter set to capacitance , I am reading 50.7uf on the board . up to now everything was reading as described .The only thing I can think to do at this point would be to take out the board and see if a jumper came off . Doubt it . Would appreciate any trouble shooting Ideas .Thanks ! John
 Post subject: Re: Tramp build
PostPosted: Sun Mar 10, 2013 5:28 pm
Check your jumpers on the board. Use the continuity function on your DMM.
PostPosted: Sun Mar 10, 2013 7:12 pm
Some how I left out the jumper wire from c1 r2 to r1 . Some how I put a jumper from c13 to r23 by mistake instead of c12 to r23
Hope nothing was negatively effected . Proceeding with startup ,the 2nd 50 uf will function with the power level . Next , tried the guitar and nothing yet , the amp is quiet ,the speaker is quit .
PostPosted: Sun Mar 10, 2013 10:44 pm
Probably a jumper missing still or a wire missing/going to the wrong spot on the tubes/controls.
PostPosted: Mon Mar 11, 2013 4:46 am
I'm getting proper voltages as indicated on drawing , VRM functions , when I touch the c. comp resistor with the multi meter probe , I hear it thru the speaker being amplified( yay so close) . I did wire the impedance switch for optional wiring . I went over the board . Not seeing anything wrong .
PostPosted: Mon Mar 11, 2013 5:21 am
It needed to be turned up more on the power and volume , and warm up a bit . GOT IT !!! works perfect ! sounds awesome ! Love it , Thanks !
PostPosted: Tue Mar 12, 2013 12:37 am
Good news! Enjoy it!
