It is currently Thu Apr 16, 2026 3:59 pm
 Post subject: New Tramp in town!
PostPosted: Sun Apr 20, 2014 12:27 pm
Hi all! I want to thank Stephen and everyone else who has posted in the forum. I spent a lot of time reading before starting my build. A special shout out to Snowy! You build post is required reading! Stephen, between your instructions and Snowy's post my Tramp appears to have no problems on start up! I used a dim bulb tester on start up. Initial voltage checks appear ok and the amp is "QUIET"! No hum or squeal. I used a infrared thermometer to check for heat and everything is running cool. Except for the nice warm tubes! I plugged my guitar in and we have sound! Whoohoo! :happydance: I had to quit at that point so I'll check her out further later today. I'm using a 8'' speaker in a Kustom tube 12 combo for the start up so I really don't know how she sounds yet. I'll post a cpl pics later too, but I shamelessly copied Snowy as much as possible. Stephen thank you for steering me toward the Tramp instead of the 18 watt. It was a blast to build! Probably habit forming! Now I have to finish that head cab ASAP.
Thanks again!
 Post subject: Re: New Tramp in town!
PostPosted: Mon Apr 21, 2014 7:14 am
Thanks for the post. We're always thrilled when another amp successfully fires up with no problems. Looking forward to pictures and extended user report.
PostPosted: Wed May 07, 2014 8:24 am
Congrats on the new Tramp build and thanks very much for the favourable mention of my build thread, building and documenting that amp was a wonderful and fun experience for me and it does make me feel good to find out it has been useful to others, wow I just realised it was 2 years ago now, where did the time go?
I hope you get as much enjoyment from your new amp as my Tramp continues to give me. :thumbsup:
Snowy
PostPosted: Thu May 15, 2014 7:57 pm
Thanks for the help Snowy! Maybe you or someone else can help. I have barely had time to play the amp due to other life issues but I decided to mod the impedance switch for El34 use following your thread. Before the mod it sounded good and loud! Now after the mod I have very little volume and it's very fizzy! :( So I swapped out the new EL34 for the original 6V6 hoping it was a bad tube. Same result. Oh, the amp is quiet and only fizzy when the guitar is strummed. Other than undoing the mod and running the 2.5k tap to the plate I don't see what I did wrong. Any ideas? I will attach pics and wait for rescue!
PostPosted: Thu May 15, 2014 11:06 pm
I know the mod works iF wired correctly bout it Is a biT of a tough mod. I can't tell from the pics if it is wired Ok. I assume you have a schematic for it.
While it is an elegant solution, We don't actually do it that way anymore. We do it with a Toggle switch.
PostPosted: Thu May 15, 2014 11:36 pm
Thanks for the reply Stephen. Good news! I found the problem. It was a bad patch cord from amp to cab. :oops: I mowed the grass after posting the plea for help. Always seems to help to walk away and clear your mind while mulling over a problem. I realized that I used a cord I just recently found in a closet. Decided to retry with a known good cord. She works and sounds great again! :happydance: I think if I had it to do over again I'd go the separate switch too. Next build! This thing is actually quite loud with a 12" speaker when cranked!
PostPosted: Thu May 15, 2014 11:42 pm
Great news to hear. Yes, with a EL34, with gain up and fat, it's a rocker!
PostPosted: Tue May 27, 2014 8:52 pm
:thumbsup: You know what, I had the same thing happen to me, I thought my Output Tranny was going South, but it was the same thing you found, a bad cable. I got caught out a bit as I had purchased two new speaker leads, one to use and one as backup and "assumed" they were new and hence "good", that is until I had a look inside the connectors. Here's my posting when it happened to me.
viewtopic.php?f=16&t=3256
Glad to here you got it sorted.
PostPosted: Tue May 27, 2014 10:14 pm
Happens with input cables too. It happened to me today. Cable was noisy and since you build amps, you figure it's the amp! But it was the cable and one I had rebuilt. :evil:
PostPosted: Wed May 28, 2014 1:21 pm
It's even worse when you cable is good and you forget to plug it in. I built a stompbox once and couldn't figure out why I had no sound with the pedal engaged or off. Amp was on. Pedal had a battery. Cable from guitar to pedal was fine. Other cable was plugged into the pedal output. D'oh! Forgot to plug that cable into the amp.
What an idiot! I was ready to throw the thing against a wall before I realized my mistake. :oops:
PostPosted: Wed May 28, 2014 1:25 pm
We've all made those mistakes
It's always a pain when you can't get your amp/pedal working then you realize you don't have tubes/ICs in.... :damntech:
PostPosted: Mon Jun 02, 2014 11:17 pm
Or the amp isn't turned on!!
