PostPosted: Thu Jun 04, 2015 11:15 am
Just got started on my Tramp head kit and noticed that the corner of the main circuit board is placed directly over the power tube socket. In fact, I can just make out that the hole for the power tube cut through half of the upper left-hand screw hole which would have secured the board to the chassis. Have I got this totally wrong? It appears to me that either the power tube or the 4 chassis mounting holes will have to be moved for clearance. The standoffs are not tall enough for the board to clear the lugs on the power tube socket.
PostPosted: Thu Jun 04, 2015 4:44 pm
Kit should include extra long standoffs or two short standoffs per bolt to stack for added height.
PostPosted: Thu Jun 04, 2015 5:35 pm
I get it - use three instead of four screws with extra long standoffs. Thanks!
PostPosted: Thu Jun 04, 2015 11:55 pm
You got it, just use 3. Pic for reference:
Snowy
