It is currently Thu Apr 16, 2026 12:35 pm
 Post subject: Standby switch
PostPosted: Fri Dec 28, 2018 8:37 pm
I bought a dpst carling switch, off, standby,on. It has 4 lugs. I want to be certain I wire it right. Point from diodes one lug, other side to b+,
So heater to center lugs and diode to last lugs?
 Post subject: Re: Standby switch
PostPosted: Sun Dec 30, 2018 9:15 am
What are you doing? Removing the Power control and installing a progressive switch?
PostPosted: Mon Dec 31, 2018 5:21 pm
Hmmm, I reckon the best option for "Standby" is to leave the amp stock and just turn the Power Level control to the "Idle" position which for me is my "Standby" position for when changing guitars or taking a break.
PostPosted: Tue Jan 01, 2019 10:48 am
That was the intention. Incorporating all that functionality in the one control.
The progressive switch is not straightforward to install but we do use it on the Triwatt so our documentation for that will show how to do it.
