It is currently Sat Dec 06, 2025 7:37 am
PostPosted: Thu Sep 01, 2016 11:27 pm
Like this..
http://support.fender.com/schematics/gu ... ematic.pdf
Simply inserted right at grid stopper / after the volume control ?
Is it possible to see any special conditions in the schematic that would prevent popping ? Are these known to pop at all ?
Anyone know what current the coil expects? Or if there are conditions that need to be in place to keep the relay supply voltage out of the signal side.
I'll probably order the triple dollar affair, it looks like it might be fun to play around with.
PostPosted: Wed Sep 14, 2016 11:02 am
Haven't tried that circuit that but at a minimum you would need to put a diode across the relay power supply. Maybe try the Tramp PAB mod first if you want a little more push.
