It is currently Tue Jun 16, 2026 12:17 pm
PostPosted: Sat Oct 20, 2018 11:39 am
I'm considering adding the extra OT impedance switch to connect the brown-white transformer wire. The Tramp layout diagram shows the centre pole connecting to V2 pin 8. I have the feeling that this should be pin 3, not pin 8. Can anyone clarify?
Thanks, Iain
PostPosted: Sun Oct 21, 2018 12:55 am
Hi Iain,
You are right. The center lug of the switch should go to V2 pin 3. It's shown correctly on the schematic.
PostPosted: Sun Oct 21, 2018 8:33 am
Thanks Mitch
After scanning the builder's guide again I found a reference in the Tone Tweaking section. It also correctly shows the switch connected to V2 pin 3.
