It is currently Sat Jun 06, 2026 10:31 pm
PostPosted: Fri Apr 19, 2019 2:40 pm
What's the best way to deal with the unused PT wires? Should they be cut shorter or is it okay to coil them up and just heat shrink the ends? I don't want to cut them if it's really not necessary. They do take up a bit of space but it's not really a problem. Any advice would be appreciated.
Thanks and Happy Easter! :)
PostPosted: Fri Apr 19, 2019 6:16 pm
You can pull back through chassis grommet, coil up, zip tie and insulate each wire with heat shrink OR clip , coil inside and insulate both end with heat shrink. Your choice. You want to make sure the clipped ends are completely covered.
PostPosted: Sat Apr 20, 2019 2:54 am
I just used heat shrink over the ends to safely insulate each one and then bundled them together neatly with a zip tie. (see the Black/White wire I didn't need).
Similar for the Output Transformer I just used heat shrink over the ends to safely insulate each one and then bundled them together neatly with a zip tie. You can see mine here in a small zip-tied bundle on the left side of the Output Transformer.
PostPosted: Sat Apr 20, 2019 9:48 pm
Very nicely done. Your soldering work looks great. Thanks very much for your input.
PostPosted: Mon Apr 22, 2019 7:57 pm
All good suggestions.
