It is currently Thu Apr 16, 2026 10:46 am
PostPosted: Mon Apr 15, 2019 9:08 pm
Prior to installing tubes got these voltages:
Line-121 VAC
Voltage at first filter cap: 89 VDC-VRM @ idle and 448 VDC-VRM @ max
Secondary Voltage: 652 VAC
Heater Voltage: 7.0 to 7.1 VAC
Build guide (pg. 48) "Leave VRM at idle and measure DC voltage on the first 50uf capacitor. It should be over 400 VDC." I am only getting over 400VDC (448VDC) with VRM at max setting. Do I need to investigate?
PostPosted: Tue Apr 16, 2019 10:53 pm
It will drop when tubes are installed.
PostPosted: Tue Apr 30, 2019 12:56 pm
I wouldn't mind seeing some clarification on this as well. I'm not there yet but without tubes your voltages should be higher and they should drop when you install the tubes. If the VRM is controlling the AC voltage level going in, shouldn't the voltage readings be low when its at its minimum level and highest at the highest level? My understanding is that the VRM is acting like a Variac. Inquiring minds would like to know.
PostPosted: Tue Apr 30, 2019 3:10 pm
Initially, without tubes, think you are making sure you have close to the correct voltages at the proper places. If you set B+ voltage to 400VDC, you should get the readings listed in the chart on pg. 52 and layout. B+2 and B+3 are on the schematic , but I'm pretty sure B+2 VDC is measured at the end of 47K power resistor above the last 33uF cap. Don't forget to plug the amp up to a load(speaker) when you test with tubes in.
PostPosted: Tue Apr 30, 2019 6:00 pm
Yep. Definitely need to make sure a speaker is hooked up before installing the tubes. I made up a cable with a 1/4" jack on one end and two terminals at the other end to do this with my first build. Are your voltages still the same as they were before or did you figure out what was going on?
PostPosted: Sun May 05, 2019 10:04 pm
The VRM controls DC voltage after rectifiation, not AC in any way!
PostPosted: Sat May 11, 2019 5:42 pm
Oops! :giggle: Thanks Stephen.
