It is currently Mon Jan 19, 2026 5:19 am
PostPosted: Fri May 03, 2019 2:57 pm
If available, could you post in Resources section OT Testing for tha Tramp as you did for Tweed, 18 Watt and 15 Watt? I may need have borked my OT!
PostPosted: Sun May 05, 2019 5:46 pm
Testing Tramp OT
If you suspect your OT for some reason, you can do a resistance check to get an idea of it's health.
Disconnect all the wires from the circuit, then use a digital ohm meter to measure the following resistances. Clip the probes to the leads, do not hold them with your fingers.
The readings may jump around but you are looking for open or short circuit anyway
Primary
Brown - Brown/Yellow: 90 ohms
Brown - Brown/White: 75 ohms
Secondary
Black - Orange (16): 11 ohms
Black - Green (8): 13 ohms
Black - Yellow (4): 17
PostPosted: Sun May 05, 2019 9:32 pm
Thank you. I want to rule out the OT (I hope). If it's bad, I'll have to purchase a new one!
