It is currently Tue Sep 01, 2026 9:04 pm
PostPosted: Thu Apr 16, 2020 5:56 pm
I'm loving the tramp. I noticed when adjusting it, whether in tweed or tude, that the amp really comes alive and sounds better within a 1/4 to 1/2 number on the volume. I have my amp setup as follows.
6v6
bass 11
treble 3-5
master 11
power 10-max
In tweed it isn't as drastic but it does sound best in the higher volumes. However tude, it amazes me that with the above settings and the volume at 6 it's ok. However if i tick it up to 6.33, it comes alive. It even seems like there is more of a volume boost in that tiny window.
Now i've known tube amps sound better when they can breathe. However i have never witnessed this drastic of a change in such a small window, and also at significantly high volume on a small amp. Is everyone having the same experience with theirs? I'm wondering if it might have something to do with the speaker in this case? As i am using 65w creamback speaker, known to be stiff (mine is well broken in getting slammed by a 50w marshall, sometimes cranked). I'm wondering if despite being broken in, it might still be too stiff for the tramp when it isn't turned up.
Thoughts anyone?
PostPosted: Fri Apr 17, 2020 2:21 am
With those tone settings, and the circuit un-modified, you have GOT to be using a Telecaster...otherwise, with humbuckers, that's a recipe for flabby bass and an almost unusable tone.
You're a Tele guy, then? ;-)
PostPosted: Fri Apr 17, 2020 3:21 am
Well i'm not a one guitar guy (trying to keep it under 7 though) :) ..
However, yes, i have been on a tele roll lately. Been digging the single coil spank
PostPosted: Fri Apr 17, 2020 9:59 am
I thought so! Those sound like Tele settings!
PostPosted: Mon Oct 19, 2020 1:01 pm
Thoughts anyone?
I've tried mine through a handful of speakers and get noticeably different responses, including spots where everything aligns and jumps out a bit. Are you using a head or a cab?
Without considering the cabinet, speaker, speaker number, impedance, room, and a dozen other variables, it's pretty hard to say "the dial on this spot always means this." I gig a good amount, and I can set up the exact same signal chain in 2 different rooms and find significantly different needs in where I put my knobs.
If I'm getting unusable tone, I change a whole lot of other things before I say "it's the circuit's fault." The first thing I'd change is how I play it. It's a different tool than I've had before, and likely requires a completely different touch to bring out what's special about it. If I'm not into the bass, I'll try a different speaker (I'm lucky enough to have some 2 speaker cabinets and I feel like they handle the larger wavelengths of bass signals in a way that delivers real richness that's difficult to get from a single speaker that's suitable for guitar.)
PostPosted: Wed Dec 02, 2020 11:51 pm
I'm currently using a Creamback Neo, which sounds great. Installed it for the weight reduction. Running a KT88 as a final. With the mid boost mod, it's LOUD! Always like to run cranked, sounds great.
I had a WGS Blackhawk HP100 Alnico. Awesome cleans.
Love the amp, both speakers great, but different.
Scott
