It is currently Sun Sep 06, 2026 7:23 pm
PostPosted: Sun Mar 16, 2008 11:02 am
When VOX re-designed their AC30 and removed the EF86, they added a Top Boost circuit to regain some of the high end sparkle the amp had lost. What was used was the high gain circuit from the 1954 Gibson. The interesting point is that the original Gibson diagrams happen to have an error on the Bass pot, grounding one end that should be left floating.
Read about the Real origins of the Top Boost circuit and why it was a mistake! The article is by Glen Lambert
http://www.geocities.com/vintage325/topboost.html
PostPosted: Sun Mar 16, 2008 7:37 pm
The Vox "Bass pot error" is also in the Matchless Hot Box.
I'm making a copy of the Hot Box right now with the "error" in place.
My 65' AC50 also has this tone control setup. When I made a single
ended 5W amp I also used this tone control type.
Lucky mistake for JMI... I guess they thought: If it sounds good why
change it? :D
PostPosted: Sun Mar 16, 2008 7:52 pm
Yes it's a unique circuit. You can defeat the interactiveness by unsoldering the ground connection from the Bass pot.
PostPosted: Mon Jul 29, 2024 9:49 pm
I too have similar tone control setup on my 65-inch AC50. When I produced just one
geometry dash lite
Users browsing this forum: Google [Bot] and 21 guests
