It is currently Sat Apr 18, 2026 12:13 am
 Post subject: Question about arcing
PostPosted: Fri Jun 29, 2007 6:30 pm
I am in the process of modifying a pre-drilled / punched steel chassis. I am adding a second output jack and impedance switch however; some of the connections will be very close to the rectifier, output and vibrato tube sockets. Some of the connections will be within 3/16â€
PostPosted: Fri Aug 10, 2007 6:36 pm
That's very close but I dont think you'll get arcing [unless you accidentally touch them both :shock: ].
I would be concerned that the tubes are too close to each other and will 'heat' one another.
