 Post subject: Tolex advice
PostPosted: Sat Nov 24, 2007 12:27 am
I've been hitting some local fabric stores as an alternative to purchasing tolex online. I've found some marine grade vinyl coverings that look exactly like what most would call tolex. Are these marine grade vinyl coverings ok to use?
Eric
PostPosted: Sat Nov 24, 2007 2:36 pm
As long as the glue you use does not 'melt' it, you should be OK. I prefer Tolex to be thicker rather than thinner. I have found the automotive grade to be decent the few times I needed to use it.
PostPosted: Mon Nov 26, 2007 10:20 pm
I have found the marine vinyl is a bit too stretchy, the best I have found so far is the stuff that was produced for vinyl roof coverings for cars, this is very similar to tolex however I could only get it in black or beige.
Nigel
