 Post subject: Part question for coco
PostPosted: Mon May 02, 2005 10:47 am
Stephen,
Got the 2 chassis on Saturday and I'm making real progress. Except for ordering the wrong input jacks (argh! I ordered unswitched mono - using some PCB ones I had instead), I need to get just one part.
What is the part # of the impedence selector you use?
Richard Johnson
PostPosted: Mon May 02, 2005 5:17 pm
We source the impedance selector locally. The part number would not be valid at US distributors. Most high current (5-20A) 1P3T rotary would work. You could wire directly to the jacks?
PostPosted: Mon May 02, 2005 10:51 pm
I'm going to wire it directly for now. I'm going to use the impedence hole for the 16 ohm tap and the other two for the 8ohm tap. But since it is the head, I'd really like to use a selector long term.
Thanks for the specs. That should make it easier to cross from Mouser. The only thing I'm concerned about is the size, since it is nder the mounting bolt.
Richard Johnson
PostPosted: Mon May 02, 2005 11:16 pm
If you're interested, for a few bucks, I can ship you one when I ship your head cab.
PostPosted: Tue May 03, 2005 4:22 pm
Can you email me the price?
Richard Johnson
