It is currently Thu Dec 04, 2025 11:01 am
PostPosted: Sat Mar 26, 2005 7:20 pm
:roll: Point me in the right direction to some info. I've heard several mentions of the name but no definite description.
Denny
PostPosted: Sun Mar 27, 2005 2:26 pm
Craig, is this the final schematic for the Atlas Tweed you speak of? I found it on your web site.
http://www.geocities.com/craigbbbb/AtlasSCHEM.html
PostPosted: Mon Apr 04, 2005 3:36 pm
Sorry, guys, been on holiday for a few days.
Yes, that is the final schematic. FWIW, before I sold it, I had been running a 5751 in the PI socket, which I preferred over the 12AX7.
CraigB
PostPosted: Mon Apr 04, 2005 8:04 pm
Cool,
The Holy Ghost is gearing up to convert an old Thomas Organ reverb amp, with 6V6s in it. It has space for 3-9 pin tubes, so we'll start simple with your circuit and see how it goes with 2 of them.
The operation looks very simple and we're loking forward to the results. I'll keep posting updates on the progress, and ultimately, sound clips of course. Just don't hold your breath too long! :lol:
PostPosted: Tue Apr 05, 2005 10:39 am
Vol, tone, master, it doesn't get much simpler than that. A guy by the name of DennisF over at ax84 made a soundclip that was impressive. I never did any recording with it, but I did use it on several gigs. Let us know how you like it - CraigB
PostPosted: Mon Apr 25, 2005 10:55 pm
Well, I just got a call from the R&D department, the amp is ready to try out! I'll be reporting back in a week with the results.
PostPosted: Mon May 02, 2005 8:05 pm
Well, we have our first version of the Atlas Tweed. So far, not quite what we expected..not enough effect by the MV control. We can't seem to get it inot sweet distortion much at all. So we replaced the 5Y3 with a 5U4 and that cranked it up a notch, then we put in a higher gain tube - another notch, but that's with everything dimed.
So, we're thinking the first stage AX17 may not be driving hard enough. We used an old cathode bypass in a can cap, for V1 so I'll replace it with new parts and see what happens.
Any other suggestions?
PostPosted: Tue May 03, 2005 4:50 pm
That's disappointing to hear. Of the several people who have built, none of them have mentioned the problems you're describing. Hopefully it's just a bad cathode bypass cap on the first stage? Also, what are you using, audio or linear taper, on the MV control? CraigB
PostPosted: Tue May 03, 2005 6:19 pm
I'm not disappointed. I'll try the cathode bypass first then post the results. The MV is a log taper.
I'm confident it will get sorted out and will result in a great sounding amp. I'm hoping one mor week of trials will do it. Stay tuned!
PostPosted: Tue May 03, 2005 10:00 pm
Just a thought though, what transformer did you use, and was it a correct match for the 6V6s?
PostPosted: Wed May 04, 2005 7:03 pm
I used a DR replacement for PT for sure, and I can't remember exactly, but I think old pull 2x6V6 OT from a VoycAll PA amp, so probably 8-10K pri.
PostPosted: Wed May 04, 2005 8:01 pm
Ok, I have one like that in my parts bag! Although the one I have looks pretty good. I'll keep you posted.
 Post subject: Atlas Tweed
PostPosted: Wed Jun 01, 2005 2:40 pm
Steve have you made any progress with your Atlas? :roll:
PostPosted: Wed Jun 01, 2005 8:54 pm
It's made and works. It's not loud enough and I cant really get it to break up nicely. I've been too busy to get back at it but I will as soon as possible. Really want to make this go!
PostPosted: Mon Jun 06, 2005 5:33 pm
Wow, I'm at a loss as to what the problem could be. I'm seriously bummed to hear that you don't like it. The one I made was every bit as loud as a 5E3, and in fact, sounded a lot like one when turned all the way up. (That was with the 5751 instead of a 12AX7.) And the few people I know of that built one loved theirs. Maybe try disconnecting the MV pot? I seem to remember you said you didn't like how that worked, which I didn't have that problem either. Dang, I hope it works out. CraigB
PostPosted: Mon Jun 06, 2005 6:21 pm
What amp doesn't require some tweaking?? It will rise & it will be Fine, Fine, Fine! At least when I get back to it. I just haven't had the time.
