It is currently Fri Apr 17, 2026 6:00 pm
PostPosted: Fri Jun 25, 2010 8:16 pm
Does anyone know how substituting the capacitors (both electrolytic & Axial caps) provided in the TC15 kit will affect the tone or performance of my TC-15 kit?
I am considering substituting the caps for either High-end Allesandro paper & oil, or Jupiter Paper & Beeswax.
Thanks for your help.
PostPosted: Sat Jun 26, 2010 1:15 pm
The caps in the TC15 sound very good. We tried SOZO & preferred the Mallorys or ETR. When I built the first 15, it was best with the Malory's. If you check out the MAtchless, you will see they are similar. Bottom line is that Paper /Oil, beeswax etc. etc. not required.
Suggest you use the ones in the kit, and sub slowly to see how the sound compares .
PostPosted: Sat Jun 26, 2010 6:41 pm
Thanks for the guidance. Will do.
PostPosted: Mon Jun 28, 2010 11:16 am
Stephen..are you still supplying Sozos with your other kits?
Stew
