It is currently Fri Apr 17, 2026 6:00 pm
 Post subject: Re: Build a bass amp
PostPosted: Tue Aug 03, 2010 11:23 pm
Perhaps you've read about the 'plans' to build a B15?? That would be my recomendation. email sent.
PostPosted: Wed Aug 04, 2010 9:09 am
Ampeg SVT maybe, they are really loud, quite a beast.
PostPosted: Wed Aug 04, 2010 11:55 am
Use the normal i/p from the triwatt
How hi power did you want to go to?
I use my Triwatt as my bass amp on a regular basis so there should be very little tweaking needed.
So it would be finding the iron for the output, probably hammond.
Use 2 - 4 o/p tubes per side, efficient speakers and you can boom with the best.
This should give a front pnl with i/p level, bass, treble, mid can be either preset or pot control.
Master volume would be up to you, I would put in a switch that would bypass the tone stack.
Not sure if VRM would be a good thing or not, but worth looking into.
Tele's make the best noise
