It is currently Thu Dec 04, 2025 8:04 am
 Post subject: Arcing rectifier
PostPosted: Sat Jul 30, 2005 7:42 pm
I have an amp running 2 X 12AX7s, a 5751 and a pair of EL84s that works beautifully however when I switch from standby to on I get an arc in the 5Y3 rectifier. Is this likley to be a duff tube, should I be concerned? The amp runs perfectly once on and there is no sign of any other arcing, the voltages are all good etc.
Nigel
PostPosted: Sun Jul 31, 2005 3:27 am
Nigel,
It looks like there are some guys talking about this over at 18watt in this thread . I can't say that I have had a rectifier arc, but then I can't recall ever really checking :lol:
Eddie
PostPosted: Sun Jul 31, 2005 9:17 am
Thanks for that Eddie, I added my 2c worth. Must have been a bad rectifier, thats one for the bin. :wink:
Nigel
PostPosted: Sun Jul 31, 2005 11:02 am
The vacuum in that tube is probably 'gassed'. You can use it, but replace as soon as you can and trash it.
